Activity Forums Adobe After Effects Shatter in 3D?
  • Shatter in 3D?
    Posted by Steven J casey on October 31, 2005 at 6:16 pm
    I wanted to use shatter in 3D space so that I could animate a camera to fly through the pieces. As it passed through the pieces it would rotate 180 degrees to see them flying/falling away and the next scene is there behind where the camera started. Picture both scenes facing each other, one shatters and the camera is turning around to see the other scene. I’m discovering that shatter isn’t actually 3D though, at least not by merely turning on the 3D switch. Can all this be done?
    thanks
    steven
    Steve Roberts replied 20 years, 10 months ago 2 Members · 1 Reply
  • Steve Roberts
    October 31, 2005 at 6:59 pm
    As is the case with all 3D effects in AE, the effect just creates a “live movie” that “plays” on a flat layer, which acts as a sort of movie screen. When you make the layer 3D, you’re just making the flat screen exist in 3D space, so if you want to flip the layer (screen) around, that’s cool, but the Shatter will still look like a movie playing on a screen.
    As for the Shatter using the Comp Camera, that’s a trick that makes the “movie” look as if it is respecting the Comp Camera. Does that make sense?
    Anyway, you need to make a 3D camera (if you haven’t already), then select “use comp camera” or such in the Shatter controls to make Shatter recognize the Comp Camera. Don’t make the Shatter layer 3D.
    Steve
