Activity › Forums › Adobe After Effects › Shatter how it uses gray scale
  • Shatter how it uses gray scale
    Posted by David Tannenbaum on May 5, 2005 at 6:20 pm
    I have been playing around with shatter for a couple of weeks. I am trying to use a gray scale graphic to control how my (target) image shatters.
    In this case the image that is being shattered is the same image to control the shatter.
    What I did was use an image that had gray boxes going from right to left. Then in the “Shape” twirl down section I set the pattern to custom and then custom shape was set to my gray boxes going from right to left. In the Gradient section I also picked my graphic of the boxes going right to left. Then I set the shatter percent to change over time from 0 percent to 100 percent.
    When I did this, the boxes did not break apart one value at a time. However, when I set the pattern to one of the built-in patterns that come with shatter, let’s say, bricks, the image shatters as expected. That is, it shattered based on the gray values from light to dark. I get the feeling that some other value is at play here.
    Just recently I read somewhere (I can’t remember where. It might have even been here at Cow.) that color may play a part.
    Can anyone give me direction? Articles, tutorials, your own experiences, etc.
    David
    Roland R. kahlenberg replied 21 years, 4 months ago 3 Members · 2 Replies
  • Matt Larson
    May 5, 2005 at 7:53 pm
    shatter can use Red Green Blue Cyan Magenta Yellow Black and White colors to create different shapes.
    (thanks to Marcus Geduld showing me that one at NAB–along with a ton of other cool tricks)
  • Roland R. kahlenberg
    May 6, 2005 at 3:34 am
    [Matt Larson] “shatter can use Red Green Blue Cyan Magenta Yellow Black and White colors to create different shapes.”
    Yes this works! What the initial Q needs to do is to create a custom map using the colors stated above – grayscale won’t do.
    Cheers
    Roland Kahlenberg
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
