Activity Forums Adobe After Effects Shatter freeze?
  • Shatter freeze?
    Posted by Ben Fallin on June 1, 2011 at 12:40 pm
    Hey there I’ve been messing around with the Shatter effect on a concrete bg. I can’t seem to get it to simply crack though. I’ve tried dropping gravity to zero, time freezing it, keyframing the forces etc. Any help would be mucho appreciated!
    Kevin Camp replied 15 years, 3 months ago 2 Members · 2 Replies
  • Ben Fallin
    June 1, 2011 at 2:26 pm
    Never mind, precompped it I’m good thanks though!
  • Kevin Camp
    June 1, 2011 at 2:35 pm
    pre-comping and time remapping (which it sounds like you may have done) would work, however if you wanted to have the pieces hold in time as a camera moved around for a bullet-time-like effect, then you could try using hold keyframes on the viscosity property and crank up the viscosity.
    if you were using shatter to extrude text — since your later post is about extruded text — then you might check out roland’s old tutorial using shatter:
    https://library.creativecow.net/articles/kahlenberg_roland/3d_logo_extrude.php
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
