Activity Forums Adobe After Effects Shatter effect question
  • Shatter effect question
    Posted by Carl Endres on June 14, 2009 at 1:52 pm
    How do you prevent particals when using the shatter effect from flying toward the camera so much.
    I’m trying to compostite breaking glass using shatter and the scene is a building about 100 feet away from the camera. I just want the glass to shatter and drop to the ground, not fly toward the camera so much.
    Any settings advice would be appreciated. – Carl
    Carl Endres replied 17 years, 3 months ago 2 Members · 2 Replies
  • Joseph W. bourke
    June 15, 2009 at 1:26 pm
    Carl –
    I believe that if you turn the gravity setting up (and of course make sure that the gravity setting is in the right direction for your scene), and turn the strength setting of the shatter down, you will achieve a fairly realistic glass shatter.
    Joe Bourke
  • Carl Endres
    June 16, 2009 at 1:21 pm
    Thanks Joe, I’ll give that a try
