Activity › Forums › Adobe After Effects › Shatter effect -How to make tiles fly away from camera?
Posted by Redgin on August 6, 2007 at 6:59 pmHey, i’m working with shatter effect. But the tiles always seem to come towards the camera. How do i make them go the opposite way?
Redgin replied 19 years, 1 month ago 2 Members · 4 Replies -
Roland R. kahlenberg
August 7, 2007 at 3:45 amSet Shatter’s Gravity Inclination to -90 and its particles will fly away from the camera.
Cheers
Roland Kahlenberg
https://www.broadcastGEMs.com – Adobe After Effects project files
https://www.myspace.com/rorkrgbspace -
August 7, 2007 at 5:08 pmOf you could set Gravity to a low value, perhaps even a small negative value BUT set Strength to a negative value. This will essentially implode rathe than explode the layer.
Cheers
Roland Kahlenberg
https://www.myspace.com/rorkrgrbspace -
Redgin
August 18, 2007 at 9:09 pmThanks for all responses, but I still can’t get this to work :/
When I parent the camera/light to the null and rotate them, the tiles still fly towards the camera. And I followed the instrucions exactly as described.
When setting the gravity inclination to -90, the tiles fly towards camera for a few frames, then they suddenly turn.
And the final version can’t work becouse the tiles simply implode to the middle of the screen, and that’s not really the effect i was looking for.
Have someone got this to work? Maybe someone have an alternative way to do this?
Any response would be highly appreciated.
