Activity Forums Adobe After Effects Shatter effect error
  • Shatter effect error
    Posted by Hamid Rohi-bilverdy on February 3, 2010 at 6:01 am
    Hi guys.
    I never had problem using AE cs4, I have almost tried using most of the plugins in some way, but last night I did Andrew Kramers planet earth tutorial, and after that, I tried to add the shatter effect, the program came up with a error message with the plugin and asked me to save before it crashed?? I tried a few times and the same problem accured.
    Only with this effect, but when I e.g take the earth map and put it in a comp or any other footage I can easyli use the shatter. It chrashed after i use CC sphere on the earth map and change the wireframe mode to render? How come it can not change to render mode with a CC sphere object?
    I hope this made any sence, otherwise I will try to explain more.
    Regards Hamid
    P.S I can easyli use BCC shatter and so on.
    William Cousert replied 16 years, 3 months ago 3 Members · 6 Replies
  • Todd Kopriva
    February 3, 2010 at 6:21 am
    Have you applied the After Effects CS4 (9.0.2) update? It fixed several crashing problems, so I want to make sure that we’re not troubleshooting a problem that can just be fixed with that update.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Hamid Rohi-bilverdy
    February 3, 2010 at 6:42 am
    Yes I did that. And strange only this effect seems to crash it!!
    February 3, 2010 at 6:33 pm
    ok I really dont understand this. If I just take the world map jpeg file and add it to the timeline and add the shatter effect to it, it works. But when I use the CC spehere effect on it, and then add shatter effect and change the view mode to render, it crashes???
    Cant the shatter work on a CC spehere image or what am i missing here??
    Please advice.
    regards Hamid
    February 3, 2010 at 7:01 pm
    Hi dave.
    Funny you just wrote that, as I was to to post my latest update on this issue, you wrote exactly what I was about to post.
    So I precomposed my layer with the CC spehere and it worked. So, behind the layer ( precomp one ) I added a solid layer under it, which is my space layer, and it did not work if i precomped that with the CC spehere, but if i add a solid under the precomp of only the world cc spehere , IT WORKS…
    Great I at last found this, I really appreciate you help Dave. Now I just have to find out how to specify the shatter effect so it wont break the hole layer but only limited to the earth.
    regards Hamid
    February 3, 2010 at 7:26 pm
    Yes I found out how and when to trigger the settings. Just have to play around a bit to see it.
    THANKS FOR EVERYTHING.
    Hamid
  • William Cousert
    June 14, 2010 at 4:41 pm
    CS5 has the same problem.
