Activity Forums Adobe After Effects shatter effect
  • shatter effect
    Posted by Ilan Eran on January 23, 2012 at 4:04 pm
    while trying to use the shatter effect, after putting it on the JPG,the central circle turns into tranparent, and the sides show the picture, and the effect doesn’t work.
    Kevin Reiner replied 14 years, 8 months ago 4 Members · 4 Replies
  • Walter Soyka
    January 23, 2012 at 4:27 pm
    [ilan eran] “while trying to use the shatter effect, after putting it on the JPG,the central circle turns into tranparent, and the sides show the picture, and the effect doesn’t work.”
    Sounds like it is working, and you’re seeing the result after Shatter has blown a hole through the center of your image.
    Have you read the documentation on the Shatter effect [link]? In addition to a description of how the effect works, there are a lot of useful links on that page.
    If I’ve misunderstood, posting a screenshot might help us understand what you’re seeing.
    Walter Soyka
  • Ilan Eran
    January 23, 2012 at 5:19 pm
    thanks, if the effect is working, how can I see the blow?
  • John Cuevas
    January 23, 2012 at 5:29 pm
    There are some tutorials on the cow that might help you out understanding shatter, this first one is quite old, but will help you grasp the basics:
    https://library.creativecow.net/articles/unguren_ben/shatter.php
    As to your question, shatter defaults with the force(the thing that makes the layer explode-it’s like a wrecking ball) right in the middle of your layer. To unexplode your layer you need to move that force either forward or backward, off the layer.
    Using the pulldown and changing it to wireframe + forces will help you see what’s going on.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Kevin Reiner
    January 23, 2012 at 6:44 pm
    Shatter effect is a great effect, but isn’t a quick effect. Definitely look at the tutorials that others have posted. I got frustrated the first time I tried to use it but once I got my head around it, I use it quite often. The controls can get pretty deep.
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
