Activity Forums Adobe After Effects Shatter Doesn’t Reflect Source Layer Changes
  • Shatter Doesn’t Reflect Source Layer Changes
    Posted by Cole Christine on November 16, 2012 at 7:08 am
    I’ve animated a Shape layer and want it to look 3D by using the Shatter 3D text trick, but for some reason Shatter doesn’t show the Shape layer animations; it only shows the first frame of the composition.
    The same is true for animated text; Shatter won’t display the changes between keyframes that I make to the source text (i.e. words spelling themselves out). Is there a way I can change this?
    Roland R. kahlenberg replied 13 years, 10 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    November 16, 2012 at 8:55 am
    [Cole Christine] “Shatter doesn’t show the Shape layer animations; it only shows the first frame of the composition.”
    This is a limitation of the Shatter effect. Shatter only invokes the first frame of the Custom Shatter Map’s shape characteristics .
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
