Activity Forums VEGAS Pro Sharpening old VHS footage
  • Sharpening old VHS footage
    Posted by Ozvideo on October 25, 2005 at 8:01 am
    I have a lot of old video which was recorded in the VHS-C format. I have captured these files an avi’s for editing. The content is good but none of the footage is what you might call sharp. Is these anyway to give the illusion that the footage is sharper that it really is? I have been told to never use the sharpen filter, if this is true how can I improve things?
    Edward Troxel replied 20 years, 10 months ago 5 Members · 6 Replies
  • Chris Borjis
    October 25, 2005 at 5:16 pm
    Honestly I don’t think you can.
    Any altering of the footage will likely make it look worse than
    it actually does.
    Just be thankful you have it off tape now.
  • Edward Troxel
    October 25, 2005 at 6:07 pm
    Try this out – thanks to John Meyer:
    “Ultimate” VHS tape restoration recipe
    Edward Troxel
    JETDV Scripts
  • Mike Kujbida
    October 25, 2005 at 10:14 pm
    Or if you want to spend some money ($550 list), buy a Canopus ADVC300. It has a built-in TBC as well as some good noise reduction circuitry.
  • Seatlanta
    October 27, 2005 at 12:05 am
    I capture old 8mm and 16mm home movies to digital format and I get improvements by using the following three effects.
    Try using the Vegas Unsharp Mask effect. Although it won’t really sharpen the image, you can make it appear sharper. A little goes a long way.
    You can also (sometimes) use Brightness and Contrast to make old videos and films look better.
    Color Correction will help take care of color shifts.
    Good luck.
    James (seatlanta)
  • Ozvideo
    October 27, 2005 at 2:23 am
    Thanks for the replys.
    I’m guessing that since these videos are already transfered to DV & the original VHS tapes aren’t available that there is no point in doing multiple captures so that they might be blended together. Correct?
  • Edward Troxel
    October 27, 2005 at 2:55 am
    [Ozvideo] “I’m guessing that since these videos are already transfered to DV & the original VHS tapes aren’t available that there is no point in doing multiple captures so that they might be blended together. Correct?”
    Correct. You’d end up with two exact copies.
    Edward Troxel
    JETDV Scripts
