Activity Forums Audio “Shark Fin” Antenna Use
  • “Shark Fin” Antenna Use
    Posted by David C jones on September 17, 2008 at 9:04 pm
    Hi All-
    I am looking at using the ALP500 “shark fin” antenna with my Lecto 411a’s, and was wondering if I need to have two for each receiver I’m using (since they’re diversity), or if I can use one shark fin and one whip antenna.
    Dave
    Greg Curda replied 17 years, 11 months ago 3 Members · 2 Replies
  • Ty Ford
    September 18, 2008 at 2:59 am
    Hello David,
    One directional antenna is not as good as two. You can, of course, move the receivers closer to the transmitters and cable back to your mixer if reception gets weak.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Greg Curda
    October 3, 2008 at 12:11 pm
    Hi guys,
    I’ve also found that you have to be very specific in your coverage of high gain, directional antennas. Often they can be a nuisance at close range, where an omni antenna would be more useful. I’ve only used them in conjunction with a multi wireless scenario and not with single units. I have sometimes switched back to the stock whips for closer work. I have also moved the whips into the action on a C stand or something with good results (keeping the coax cable run as short as possible). David’s idea of paddle and whip combo might be good for a long, tracking “walk and talk” where you need the range at first, but end up close…If you try it, will you let me know how it works??
    G
