Activity › Forums › Apple Final Cut Pro Legacy › sharing rendered files in FCP between ediing rooms
Posted by Gary Giambalvo on January 28, 2010 at 9:56 pmWas wondering if their is a way to share rendered files between edit suites?
Vladimir Uschintsky replied 16 years, 7 months ago 3 Members · 2 Replies -
Shane Ross
January 28, 2010 at 10:40 pmJust the rendered files, or all the media when you edit? Why just the rendered files?
If you want to share footage/renders between two or more edit stations, you need to look into a SAN setup of some sort.
Shane
Read my blog, Little Frog in High Def -
Vladimir Uschintsky
February 2, 2010 at 1:53 pmWe have a SAN and frequently share rendered files between rooms. You may occasionally have to relink the renders when you open the same project in a different suite, but otherwise it generally works OK.
WHERE IT DOES NOT WORK OK is if one editor begins a project, then makes a copy of that project for another editor to create an alternate version from. For instance, the first project is in English and then the copy is used by a second editor to create a Spanish version. As the second editor begins replacing, say, an English bug with the Spanish equivalent Final Cut assumes that the original renders are now useless and deletes them, hosing the first editor on the original project.
