Activity › Forums › Avid Media Composer › Sharing Projects Between Xpress and Adrenaline
  • Sharing Projects Between Xpress and Adrenaline
    Posted by Accountneedsrealnameupdate on June 21, 2005 at 3:12 am
    If I need to access a project with an Adrenaline that is created on an Xpress, how would that work? Could I just open it with Adrenaline from a shared drive?
    O_ren replied 21 years, 3 months ago 4 Members · 5 Replies
  • Michael Phillips
    June 21, 2005 at 11:33 am
    You can just copy it over on a USB drive, you can open it from a networked disk, etc.
  • Chris Magid
    June 21, 2005 at 2:00 pm
    What resolution is it?
    While I do not recomended network sharing as a permanent solution. If you are just giving something a quick look you may be able to just simply share the media drive(s) on your Xpress and just move the project file over.
    To get Adrenaline to see regular windows networked shares as media drives, you will need to enter the “alldrives” command in the console of the Adrenaline.
    Keep in mind when moving the project file over, you will encounter a few error dialog boxes as there are different settings for Xpress and Adrenaline projects. These typically are no big deal to just click through.
    Also, I would recommend nothing but a gigabit ethernet to attempt this over. DV is probably going the highest resolution you will be able to work with. Don’t know what version of Xpress you speak of, but 10:1, 15:1 and like compression levels work well.
    chris magid
    chris@gortvf.com
  • Accountneedsrealnameupdate
    June 21, 2005 at 2:15 pm
    Can you access the project that was created with xpress on unity and redigitize the media in adrenaline?
  • Chris Magid
    June 22, 2005 at 3:48 pm
    YES
  • O_ren
    July 4, 2005 at 4:46 pm
    although you can open xpress projects on adrenaline (and back) it’s always better to use open bin to open bins from the previous project
