Activity Forums Adobe Premiere Pro Sharing projects between editors
  • Sharing projects between editors
    Posted by Frank Raposo on November 16, 2011 at 10:37 pm
    Hi All. I’m looking for advice on a workflow that would allow several editors to work on a project simultaneously in Premiere. For example, in Avid, you can share bins, in FCP, you can create different projects, as if they were bins, and open them up simultaneously within FCP. How do you do this in Premiere? Thanks in advance.
    quinnmcguee
    Jon Barrie replied 14 years, 9 months ago 4 Members · 3 Replies
  • Alex Udell
    November 18, 2011 at 3:02 pm
    Shoot me an e-mail and let’s try to get in voice contact.
    this is hard to do with typing only….
    Alex
    audell999 (at) yahoo (dot) com
  • Simon Smith
    December 8, 2011 at 1:20 am
    Hi Alex, would be great if you can share anything with the forum, I’d be keen to know more about this too.
  • Jon Barrie
    December 8, 2011 at 10:55 am
    Based on the idea behind the FCP workflow, whereby multiple editors work on separate projects that are dedicated areas of a single production to be brought together later, Premiere Pro can have multiple projects as such and then a master project can import the other projects and select either the entire project with everything being imported, including the bin structures or import just selected sequences and only the assets used in the imported sequences.
    In this, 1 Master project contains all the imported projects instead of having mutliple projects open at the same time, which can create problems when someone saves over the original edit and the state of the project is never certain in the event of a power outage or app crash, whereby important things are accidentally deleted.
    PPro’s workflow of importing projects or sequences with associated assets used leaves the original edits alone and therefore the originating editors can continue to work on them and make updates with specific new sequences that can then be imported and be used to replace or compare with older imports. The original project is never compromised.
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
