Activity Forums Apple Motion Sharing MotionTemplates with other users and machines…
  • Sharing MotionTemplates with other users and machines…
    Posted by Helge Tjelta on September 1, 2012 at 2:51 pm
    Since FCPX does only read motiontemplates from localusers home folder and inside movies only, here is the trick…:
    Create a symbolic link to a shared location, NOT an alias, but symbolic link….
    open terminal, do a cd to your movies folder
    remove motion templates
    and type in:
    ln -s /Volumes/SharedDisk/folderForTemplates/ Motion Templates.localized
    pay attention to .localized I had to put this on otherwise it would not do it.
    Now open fcpx and it reads motiontemplates from the shared location.
    (Thanks to Lars Petter for getting me on the right track)
    cheers Helge Tjelta
    Helge
    Mark Spencer replied 13 years, 3 months ago 4 Members · 6 Replies
  • Yarrow Sweningsen
    April 8, 2013 at 10:18 pm
    Hi Helge, this is exactly what I am attempting to do, but can’t duplicate from your instructions. Can you please check them carefully and make sure they are complete and exactly correct? Thanks!
    Yarrow
  • Yarrow Sweningsen
    April 8, 2013 at 10:32 pm
    I figured out the problem: I was not entering the path to the disk correctly. I dragged the Motion Templates folder into the Terminal window after typing ln -s and then got the correct path, which worked. Thanks!
  • William Davis
    May 20, 2013 at 7:27 pm
    Greetings all-
    I’m starting to test this on our Xsan environment as well. I’m curious to know what happens if more than one user is accessing the folder at the same time and someone generates new content (title, transition, filter, etc.)- do the other editors see this update live or do you only see it upon relaunching FCP? Also, what happens if more than one user is working from the same template at the same time?
    Bill
  • Mark Spencer
    June 2, 2013 at 2:09 pm
    Bill, what have you discovered?
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • William Davis
    June 3, 2013 at 9:08 pm
    Hey Mark-
    It seems to work, but it’s risky. Since there’s no server-side management of the files, there is always the possibility that another editor will open and modify a project that you are using in a project. This is a big hole in the workflow for FCP X editors working in a shared environment, and one that I hope Apple closes soon.
    Bill
  • Mark Spencer
    June 4, 2013 at 3:52 pm
    Agreed, Bill, thanks for posting back.
    Mark Spencer
