Activity › Forums › Apple Final Cut Pro Legacy › Sharing FCP Project
Sharing FCP Project
Posted by Elaine Lake on April 29, 2014 at 7:57 pmI’ve been editing a project on my computer and need another editor to take over. Is there a way to send the FCP Project without giving them my external hard drive or having to burn multiple DVDs of the footage & project file? Thanks for your help!
Mark Suszko replied 12 years ago 4 Members · 5 Replies -
Daryl K davis
April 29, 2014 at 8:02 pmWhen I’ve come across this situation I generally send/receive the backup media hard-drive. Then they can copy over media from that to their hard-drive.
DK Davis / Editor/ Post Super
Mark Suszko
April 29, 2014 at 8:05 pmProject files are relatively compact. They are separate from the media files, just like an ipod playlist is very tiny, and only describes the play order of the mp-3 files in your ipod, it doesn’t include the music.
Project files alone could fit on a DVD-R or a BluRay, or could go into a Drop box or similar type of FTP program, and be transferred by internet. Short ones might even fit as an email attachment. Proxy versions of the media files take up less space, but have to be replaced with the real media at the final rendering stage.
The media files are often more easy to send as a cloned hard drive mailed by overnight service. Once both parties have identical drives with the same media files, trading updated project files by internet of FTP is generally a piece of cake.
Elaine Lake
April 29, 2014 at 8:18 pmThank you so much!
Mark would I find the project files and compress them into a deliverable file via DropBox? -
Shane Ross
April 29, 2014 at 8:30 pmThey still need the media. If they get the project file only, they’ll see the bins and the sequence and all the clips, but everything will be offline. You need to copy all the media to another drive and send it to them. Sending the media via dropbox will be time consuming and drive consuming, to say the least. Not practical.
They need the project and media.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Mark Suszko
April 29, 2014 at 8:52 pmI’m saying it’s not too hard to collect the project files and transfer them via Drop Box, any time you update the project . The Project files, as Scott says, are useless without the media, which you copy to a drive and physically ship overnight by FedEx or whatever. The other editor puts it all together at their end, and everything should re-connect. From that point, when the remote person makes changes, they only have to FTP you the updated project file, which you plug into your end, and you can see what the changes are.
