Activity Forums Adobe Premiere Pro Sharing between Macs and PC’s
  • Sharing between Macs and PC’s
    Posted by Mitch Jordan on October 8, 2015 at 2:11 pm
    We are adding a PC to our shop of MacPros all connected by servers, but I’ve run into a few problems. I was wondering if anyone else has already tackled these issues and can give us some solutions.
    We normally have saved our media as ProRes. I downloaded the ProRes codec for the PC, and I can see the ProRes422 files fine. However, I get an error message with ProRes 4444 files with an alpha channel on the PC. Doesn’t the ProRes codec for PC include 4444? Also, I can’t write to ProRes from the PC. What codec do you like to use to share between PC’s and Macs? I can use H.264, but I was looking for something more lossless.
    Also, Macs and PC’s map their drives differently with PC’s adding a drive letter. Everytime we open a Premiere Pro project on one platform that was last edited on the other, we have to relink all the media. Has anyone found a solution for that?
    Thanks for any advice.
    Jon Frost replied 10 years, 10 months ago 3 Members · 2 Replies
  • Chris Borjis
    October 8, 2015 at 4:42 pm
    the Avid DnxHD codec is a good go-between for import/export between platforms.
  • Jon Frost
    October 24, 2015 at 1:33 am
    You might consider formatting your media drives for eFAT which works on both PC and MAC. Someone else could advise you on the naming issues.
    Jon Frost
    Easthampton MA
