Activity Forums Storage & Archiving Shared Storage Newb – Help with Final Cut options
  • Shared Storage Newb – Help with Final Cut options
    Posted by Kevin Dooley on February 25, 2010 at 8:26 pm
    I am the video director of a decent sized church in the Dallas area. We currently have 9.35Tb of filled storage spread across a couple different NAS solutions and we also have 3-5Tb worth of external drives that are full… we are in desperate need of centralized, shared storage and I don’t have the foggiest about where to begin. We currently have 7 Final Cut edit stations. Half of those also have a laptop that is used when in the field and 3 of the stations only edit during our busier seasons (Christmas and Easter). We have moved over the past several years to tapeless acquisition, so all of our raw footage exists in hard drive form. We have done our best to have redundancy, but expensive losses have occurred. We are currently shooting primarily in 1080p (30 and 24fps) and do not use offline editing. Our pieces vary in length – most are 30 seconds to 10 minutes. Projects over 10 minutes are often shot in SD and can run up to 1 hour. We use ProRes for just about everything, though much of the SD footage stays as DV/DVCPRO. I have no idea where to go and need some help.
    Here are some things we need:
    Scalable, centralized storage with probably 20-25Tb at a minimum to begin with
    Media management (we’re considering Final Cut Server)
    Dedicated backup of footage (or the whole RAID – I don’t know that we want to simply rely on RAID parity as our backup).
    We would like to have the ability to edit from the storage – which is why I started looking at SANs with FC capabilities, but I really don’t know the first thing about these kinds of things. I do know that we are starting to eat up storage space with duplicates (beyond the backups) of footage and projects as people pull footage to their local machine to work because the NAS can’t keep up and then archive the whole project with the footage they pulled locally instead of pointing back to the original footage.
    The boss wants options (with pricing of course), but I need to make a hard recommendation of what I think we should do – something I can’t do without more info. We know it will cost and we’d rather buy once and do it right. So any help you guys can give getting me pointed in the right direction would be a huge help.
    We recently toured a church that had an XSan with a Promise RAID. It was around 100Tb and had FC run to all 10 of it’s editors. They used a JBOD backup (also 100Tb) with Atempo Time
    Navigator managing the back up – it looks for changes on the SAN and copies them over. Seemed a good setup – but I don’t know what options there are.
    Thanks for the help!
    Kevin Dooley
    Video Director
    Lake Pointe Church
    David Gagne replied 16 years, 5 months ago 6 Members · 12 Replies
  • 12 Replies
  • Matt Geier
    February 25, 2010 at 9:31 pm
    Hi Kevin,
    What you want to do can be done with an OSX Environment with the use of some Small Tree equipment.
    You may want to check out the Small Tree forum or give them a call and discuss available options and pricing for your situation.
    https://forums.creativecow.net/smalltree
    Matt G
  • John West
    February 25, 2010 at 10:46 pm
    Kevin,
    You may want to check out our Final Share system. You can have as many as ten client working on the Final Share System at one time. This is an affordable shared storage solution through Ethernet.
    If you would like I would be happy to send you a power point presentation about Final Share feel free to contact me at johnwest@maxxdigital.com or my number is 714-374-4944.
    Cheers,
    John West
  • Kevin Dooley
    February 25, 2010 at 11:02 pm
    John and Matt –
    I’ve been looking at both of your products, and it does seem like they would handle our current workflow. The thing I’m not wrapping my mind around is how does something like Final Cut Server tie in with a system like this? Is it installed on the same server? Is it run on a separate “server” and just tied into the switch? Do I think interface with the storage only through FCS – or do I mount the storage like a drive and have access to it that way as well? Sorry if this seems painfully obvious to most, but I haven’t worked in with a system like this before and am having some trouble visualizing it.
    Kevin Dooley
    Video Director
    Lake Pointe Church
  • John West
    February 25, 2010 at 11:12 pm
    Kevin,
    The server would need to be a Mac pro. You can use a quad core with 8 gigs of ram up to 7 clients and if you go 8-10 clients you would need a an eight Core Mac pro with 16 gigs of ram as the server. You would not be able to edit on the server computer it would just need to sit there and do its job.
    John
  • Kevin Dooley
    February 25, 2010 at 11:29 pm
    Oh no – I wouldn’t think of trying to edit on it, I’m just wondering how Final Cut Server fits into this whole thing…
    Kevin Dooley
    Video Director
    Lake Pointe Church
  • Bob Zelin
    February 26, 2010 at 4:59 am
    Hi Kevin,
    I write this to you, while sitting at Disney Broadcast Operations, who uses both Maxx Digital Final Share, and Apple XSAN with two Active Storage arrays. Kevin, 100 TB is more than a major company uses. Do you know how much this costs ? If you have the money, then go for it – get your XSAN system with ACTIVE storage, not Promise VTrak (a big mistake), but you are missing one thing – the TRAINED IT ADMINISTRATOR to run this. Just because you may have the money, does not mean that it’s easy to use, or easy to adminstrate with all of these users (both MAC Pros and Laptops, with LOTS of different users). Your description is as complex as a mid size TV station with lots of editors and producers that work on this gear. If you don’t have the staff to handle this (and the budget to pay them), then this will all blow up in your face.
    Systems like Final Share, Granite Stor, Apace, and other simple systems are not complex, and are much easier to use, but will not give you the flexibility that you may want. With that flexibilty comes complexity in the system – once you start talking about Final Cut Server, archive solutions (like an LTO4A), and all the other stuff that you want, you have one complex system. I hope you are prepared for this – this is NOT for a “newb” as you describe yourself.
    Bob Zelin
  • Kevin Dooley
    February 26, 2010 at 5:43 am
    Bob,
    Thanks for the warnings – though I believe you are mixing part of what I was asking about and part of what I was saying I saw recently. The 100Tb system was at a facility I recently toured and included several (I believe around 10) edit stations. This is way more than we need (and indeed the cost is way more than we could afford).
    I am looking for something much smaller (though maybe not simpler). We do have a dedicated IT staff at our facility to help us administer it, but we definitely will be paying someone to engineer whatever system we end up going with.
    Again, I was trying to lay out what I believe our needs are and was hoping to get some knowledge and contacts to move towards an implemented solution. I appreciate the warnings, but would more appreciate solutions. The contacts with Small Tree and Maxx Digital are helping me explore options – what are options you feel I should look at?
    Kevin Dooley
    Video Director
    Lake Pointe Church
  • Bob Zelin
    February 26, 2010 at 1:38 pm
    Hi Kevin –
    as you point out, critical for you is Final Cut Server. I am not an expert in this application, and my clients that use it, use it as a stand alone application on a seperate computer, to examine the media on their drive arrays, and create proxy files. This can also be done with CAT-DV, but the bottom line is that I am not qualified to give you the specific answer you need (exactly how will I use Final Cut Server with my shared enviornment).
    Today it is very easy to sell you a single 16 bay drive chassis with 2 terabyte drives, giving you 32 terabytes, and it is very easy to expand beyond this with simple daisy chaining of the drive chassis. But it all comes back to your most important question – how will this implement with Final Cut Server – I can only give you broad answers, that will not answer specific questions that you need answered.
    Now, there IS a Final Cut Server (and CAT DV) forum on Creative Cow, that may help you address these questions – certainly better than I can.
    Bob Zelin
  • Jordan Woods
    March 3, 2010 at 11:58 pm
    With any basic edit station build out, all you need to tell an integrator is the following information:
    -Number of edit bays working at the same time
    -Take that number and multiply it by 3 for number of streams of
    video at any given time by one edit bay.
    -Maximum compression and frame size you expect to work with on each edit bay.
    -Total space needed on the Volume at max work time.
    -Approximate value you hope to spend to accomplish this task.
    If you have this solidified you will nail your solution on the first call to an integrator.
    -Jordan
    Senior Systems Engineer
    Active Storage
    Los Angeles, CA
  • Kevin Dooley
    March 4, 2010 at 3:04 am
    Jordan,
    Excellent information – that definitely helps me talk intelligently to vendors/integrators. Thanks!
    Kevin Dooley
    Video Director
    Lake Pointe Church
