Activity Forums Apple Final Cut Pro Legacy share thoughts? sync frame rate advice…
  • share thoughts? sync frame rate advice…
    Posted by Hector Berrebi on March 12, 2009 at 8:25 am
    I work with this director, whom in a moment of blazing inspiration came up with a creative way to poke my brain.
    this is what i’m facing, and on a deadline.
    he shot a singer’s CU in 50 FPS (2K on RED) and handed me the footage to prep for second day of shooting where he will project the sync on a large screen, behind a busy set, which he will shoot LS, 5 FPS.
    he wants the final footage to have the screen in sync with the actual song.
    i figured i have to slow the sync to 40%
    my question is, do you think it will sync correctly? and which would be the bast way to render the slow sync, considering it will be re-shot in 5FPS later,
    frame blending on? off? optical flow?
    would love to be able to test, but was told about this last night and delivering it today.
    thanks
    Hector Berrebi
    Schibber Group
    prePost Consulting
    Michael Gissing replied 17 years, 6 months ago 3 Members · 6 Replies
  • Michael Gissing
    March 12, 2009 at 8:38 am
    What is the final frame rate? I hope it is 25 for your sake.
    When he shot the singer at 50 fps was he miming to the song played at double speed or normal speed? Without knowing these things, I can’t guess what you are dealing with.
    Also tell the director that without a pre production meeting with this sort of thing planned, he is an idiot.
  • Hector Berrebi
    March 12, 2009 at 9:00 am
    Michael
    i try not to tell my clients things of this sort… at least not before they pay 🙂
    he shot 50 fps, singer singing normally, not a faster version.
    final output of course is 25 fps
    thanks
    Hector Berrebi
    Schibber Group
    prePost Consulting
  • Rafael Amador
    March 12, 2009 at 10:51 am
    [Hector berrebi] ” and which would be the bast way to render the slow sync, “
    If you go to slow 50%, just conform the clip to p25. Perfect slow down. No rendering.
    If you want to slow further, Optic Flow.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Michael Gissing
    March 12, 2009 at 11:03 am
    Firstly the 50 fps will not sync in the final 25 frame timeline. It will play like a slow mo and will need to be sped up 50% to sync. This will make it look like normal motion, defeating the purpose of overcranking.
    To make it seem like sync when shooting at 5 fps, it will need to run 80% slower. This is because the lip sync playback was not double speed to match the 50 fps frame rate. Otherwise your estimate of 40% would be correct.
    In other words, the playback rate needs to be proportional to the 5 fps. As this is 20% of your base frame rate, everything sync has to be slowed by that amount including any further playback to lip sync to.
    The director made a mistake shooting the singer at 50fps without speeding up the playback x 2 to lip sync. I appreciate you can’t tell him of his basic mistakes. The client is always right – especially when they are wrong.
  • Hector Berrebi
    March 12, 2009 at 11:50 am
    Michael
    i think you got this slightly off…
    if i wanted an effect of everything slow but her mouth (or the opposite) i would need to record her singing fast or slow matching the frame rate. we play with these options once in a while..
    however, in this case, the slow footage is projected, re-shot at 5 fps there for sped up, back (hopefully) to sync.
    if i take the 50 FPS footage and turn it to 200% it syncs
    so if i export it as 40% turning it to 20% of original, when its shot at 5 fps it will go back to 100%
    Rafael. eventually its what i wanted to go with, but too tight of a deadline and no time for renders… will go with blended at best render settings
    thanks
    Hector Berrebi
    Schibber Group
    prePost Consulting
  • Michael Gissing
    March 12, 2009 at 11:55 am
    Yes, I have been thinking about this instead of going to bed and getting up for an early morning flight so I am doing too many things at once.
    Yes the 40% is correct.
