Activity Forums Apple Motion Shards of Glass Picture Effect
  • Shards of Glass Picture Effect
    Posted by Benjamin Daines on December 11, 2008 at 12:00 am
    Hello, I am trying to put together a credits sequence with pictures that are sliced up (already have this part done in photoshop saved as psd files) as if they were on pieces of broken glass. I would like them to quickly move into a central point (completing the picture), then have them slowly drift past over each other, then after a bit have them quickly break apart while spinning on their X and Y axis while moving back into the 3D space and fade away. Any idea on how to do this?
    –Thanks so much.
    David Bogie replied 17 years, 9 months ago 3 Members · 4 Replies
  • Benjamin Daines
    December 11, 2008 at 3:06 pm
    If this is not possible in Motion, could you recommend another application to use? After Effects?
  • Stephen Smith
    December 11, 2008 at 5:48 pm
    If you want 3D glass like in the Max Payne open you will need to go with a 3D program. If you don’t want to rotate your glass in 3D space it could be done in AE or Motion.
    Salt Lake Video
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • Stephen Smith
    December 11, 2008 at 9:53 pm
    You may want to take a look at the glass on the Compositor’s ToolKit.
    Salt Lake Video
  • David Bogie
    December 13, 2008 at 5:03 pm
    AE has Shatter and there’s a preset for Glass. It’s wonderful and has surface reflectivity. But it has no refraction or transmission settings. For those, as Stephen says, you must have a 3D modeler.
    But setting up your idea in Shatter won’t be easy as it is designed to run all of its physics simulations forward from a static state. Making thing assemble instead of blow up is almost impossible. The parameters just aren’t designed that way.
    Never seen the movie you guys are referring to so I don’t know what those credits are supposed to look like.
    bogiesan
