Activity Forums Boris FX Particle Illusion shapes from other libarys
  • shapes from other libarys
    Posted by Samuel Kent on June 27, 2009 at 6:39 pm
    i was just wondering if there was some way to take a load of shapes from other libary’s to put into a blank one, because its really annoying having to make my own ones, and this would be EXTREMELY useful
    thanks in advance,
    sam k
    Samuel Kent replied 17 years, 2 months ago 2 Members · 2 Replies
  • John Holste
    June 28, 2009 at 2:09 pm
    Sam,
    one way is to use the “properties” dialog in the Library window, click the “Particles” tab and “Change Shape” tab, just select the Shape you want to copy and export it(the diskette shaped icon), repeat this for every shape you want to copy, then open up your “blank” library and load(the folder with a +) the exported shape(s).
    a second way is to use the “Manage” function to copy an emitter that uses the “shape” you want to a blank library, then delete the emitter using the “properties” function.
    John
  • Samuel Kent
    June 28, 2009 at 5:48 pm
    thanks for that, really helpful
