Activity › Forums › Adobe After Effects › Shapes and Masks change when they are exported
Posted by Julie Kindinger on June 20, 2011 at 12:55 pmI have a composition that is a series of shapes and masks that make up lower thirds to be inserted into video projects. They look perfect when I am working in the after effects project and there are no cameras involved. However, every time I go to export the composition some of the shapes and masks shift. Why is this happening and how can I fix it?
Julie Kindinger replied 15 years, 3 months ago 3 Members · 9 Replies -
Steve Renard
June 20, 2011 at 2:34 pmWhat do you mean when you say “export the composition”? Do you mean rendering it? Or bringing some part of the comp into another program somehow?
Julie Kindinger
June 20, 2011 at 5:42 pmI’m sorry I do mean rendering. I put the composition into the render queue.
Todd Kopriva
June 21, 2011 at 1:17 amHow do they shift? Screenshots might help.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Julie Kindinger
June 21, 2011 at 3:51 pmI have attached a few screen shots that demonstrate how the layers are changing but how they also look correct in after effects prior to rendering in the render queue. Thanks for any advice or help that you can provide. I put a red background behind the lower third to help show the shift.
a href=’https://i1.creativecow.net/u/206025/screenshotlowerthirdinae.jpg’>
Julie Kindinger
June 21, 2011 at 4:36 pmThanks I will try changing them to 2D layers. The main reason that they were 3D is for other effects that we added later with text and our logo.
Julie Kindinger
June 21, 2011 at 5:08 pm -
Todd Kopriva
June 21, 2011 at 6:57 pmWhy are you previewing through the Front view?
The final output is rendered through the active camera, so you should be previewing through the Active Camera view if you want to see what the final output is going to look like.
See this page for information about 3D views.
Steve Renard
June 21, 2011 at 7:17 pmIt’s not clear from this screen grab what the globe should look like, and what you’re looking at in AE that’s different. I know you posted a grab of it before but it’s still a bit ambiguous on this end.
It would be helpful, too, if you could post a screen grab from within AE with at least the FX visible for each layer so we can see what’s going on. I can see that the scale isn’t working, but it does appear that some effects aren’t hitting that layer either.
And as either Todd or Dave said, always preview in “Active Camera” so that you know what you’re looking at.
Steve Renard
Media Director, Cicada Design Inc.
and Freelance Know-it-all
647-406-7991
srenard@cicadadesign.ca
http://www.cicadadesign.ca -
Julie Kindinger
June 21, 2011 at 8:00 pmI will work on getting those requested screen grabs, but there are no cameras involved in the composition and when I switch to active camera it does not change anything. Everything still looks correct in AE.
