Activity Forums Adobe After Effects Shape specific ripple / pulse from alpha.
  • Shape specific ripple / pulse from alpha.
    Posted by Stuart Paciej on February 16, 2012 at 10:50 am
    Hi everyone,
    I have an endpage resolve which I want to accent with a ripple. I will be using a displacement map to do so.
    What I need is to make a ripple or pulse in the shape of the logo and text shape. As oppose to rendering a circular ripple.
    The output needs to be a simple b/w luma channel so I can use it with the displacement. So creating a halo which grows would suffice, for example the radiowave plugin if it could take its shape from the alpha channel of my logotype.
    I had a try with using stacked glows (e.g. a large radius in white and then a smaller one in black to get get a growing halo (ripple) but seems like there should be a better way?
    A nudge in the right direction / name of a plugin to solve my problems would be great!
    Stuart
    Stuart Paciej replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
