Activity Forums Adobe After Effects Shape Rectangle roundness scaling with size?
  • Shape Rectangle roundness scaling with size?
    Posted by Tristan Summers on November 6, 2018 at 12:47 pm
    Hi
    I am setting the size of a rectangle with SourceRect of a text box, = a control slider for padding.
    When the padding is at zero the Roundedness of the Rectangle is correct, but when this is increased, the roundedness also increases.
    I assume this is an order of operations thing, but normally size changes do not effect roundedness.
    Any tips?
    This is the expression on the rectangle:
    var s1=thisComp.layer(“Line 1”);
    var s2=thisComp.layer(“Line 2”);
    var w = thisComp.layer(“CONTROL”).effect(“LARGEST WIDTH”)(“Slider”)+thisComp.layer(“CONTROL”).effect(“PADDING”)(“Slider”);
    var h =(s1.sourceRectAtTime(-1, true).height)+(s2.sourceRectAtTime(-1,true).height)+thisComp.layer(“CONTROL”).effect(“PADDING”)(“Slider”);
    [w, h]
    Tristan Summers replied 7 years, 9 months ago 1 Member · 1 Reply
  • Tristan Summers
    November 6, 2018 at 2:50 pm
    ignore me. I found a hidden offset paths that was causing it
