Activity Forums Adobe After Effects Shape Morphing
  • Blaise Douros
    April 26, 2021 at 11:19 pm
    This won’t solve ALL your problems, but make sure that you’ve set the First Vertex for each shape keyframe so that the motion is advantageous: https://vimeo.com/187300527
    Basically, this lets you say to AE “hey, when you morph between these two shapes, you should make THIS point on shape 1 move to THIS point on shape 2.”
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Chris Ellingworth
    April 27, 2021 at 12:02 am
    Brilliant! Thanks so much for your help!
