Activity › Forums › Apple Final Cut Pro › Shape masks and colour masks
Posted by James Ewart on July 20, 2015 at 9:20 amHello
I’ve applied a black and white colour shape mask to a clip. Now I have something passing through my shape that I would like to remain black and white.
I think I can apply some kind of extra colour mask to the clip but have tried a few things and can’t quite figure it out.
Help much appreciated.
James Ewart replied 11 years, 2 months ago 3 Members · 9 Replies -
Noah Kadner
July 20, 2015 at 6:54 pmThat’s a bit beyond the capabilities of the stock color board to be honest. For ways to achieve what I’d imagine you’re after, grab a cup of coffee and sit down for 30 minutes to check out:
https://www.youtube.com/watch?v=boTkHF73Dkg
Noah
FCPWORKS – FCPX Workflow
Call Box TrainingSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
James Ewart
July 20, 2015 at 6:56 pmthanks.. I was wondering if i could add colour frame by frame as the shot is only about 50 frames..i’ll check the link
appreciated
Noah Kadner
July 20, 2015 at 8:11 pmSure you could take it into Photoshop if you *really* want to get your hands dirty. But end of the day it’s your time or your money.
Noah
Call Box Training -
Jacob Brown
July 20, 2015 at 10:57 pmvideo isnt loading for me, but why not just draw a mask around the face and track it by hand if only 50 frames?
Noah Kadner
July 20, 2015 at 11:19 pmTotally. If 2-3 hours of your own time vs. a plugin you could reuse on other projects makes more sense- that’s the way to go.
Noah
Call Box Training -
James Ewart
July 21, 2015 at 5:38 am[Jacob Brown] “video isnt loading for me, but why not just draw a mask around the face and track it by hand if only 50 frames?”
Thanks that’s exactly what I have done. there is a link also. But what when an arm passes through that mask is my problem.
Downloaded Color Finale and will have a play thanks.
Jacob Brown
July 21, 2015 at 2:43 pmcool. color finale is an AWESOME tool for color. i usually use the fcpx tool to do a quick shadows/highlights/saturation adjustment on an adjustment layer, then put color finale on a second layer to add a LUT and use the color wheels to do some fine tuning.
but i’m not sure how color finale will help with your key?
do you use slicex/trackx? it has a really powerful masking tool that it can then track — i believe that it plays well with color finale, though i haven’t used them together yet.
Jacob Brown
July 21, 2015 at 2:46 pmnoah am curious what you meant by using Color Finale for masking?
is that in combo with SliceX?
i usually attempt to do keyframes by hand in FCPX, but if it’s a 2-3 hour type ordeal, then no of course that’s a waste, and i use slicex (unless i’m really feeling adventurous and want to go into resolve).
i’ve read that slicex+colorfinale is good combo for some things though…
James Ewart
July 21, 2015 at 4:33 pm[Jacob Brown] ” usually attempt to do keyframes by hand in FCPX, but if it’s a 2-3 hour type ordeal, then no of course that’s a waste, and i use slicex (unless i’m really feeling adventurous and want to go into resolve).”
As it’s such a short clip I would be happy to manually colour in 20 or 30 frames with the dropper to keep the passing arm black and white rather than download and learn new software (which I know I must learn moving forwards).
So if some clever person knew a way of doing it within FCPX that would be most welcome.
I am an editor and not a compositor or colourist (I know some of you clever people wear all these hats) so I’m a bit muddled about effects and layering in a particular order them and whether I could apply an additional colour mask in some way to get round my problem.
