Activity Forums Adobe After Effects Expressions Shape Layer’s Repeater to influence Ellipse Size
  • Shape Layer’s Repeater to influence Ellipse Size
    Posted by Pedro Amaral on August 15, 2016 at 6:23 pm
    I have a circular shape layer with a repeater (3 copies on scale).
    As I increase the scale size of the repeater I would like the shape layer’s size to increase that same amount.
    Now to complicate things a little I have an array of other shape layers that are picking up animated values from LEAD layer on top and a delay system controlled through slider controls on a Null object.
    My expression for the shape layer size, for example, looks like this:
    var frameDelay = thisComp.layer(“CONTROLER”).effect(“Delay Pos”)(“Slider”) ;
    var delay = framesToTime(frameDelay) ;
    var itemAbove = thisComp.layer(index-1).content(“Ellipse 1”).content(“Ellipse Path 1”).size;
    var amountx = thisComp.layer(“CONTROLER”).effect(“Amount CircSize”)(“Slider”);
    var amounty = thisComp.layer(“CONTROLER”).effect(“Amount CircSize”)(“Slider”);
    var x = itemAbove.valueAtTime(time-delay)[0] + amountx;
    var y =itemAbove.valueAtTime(time-delay)[1] + amounty;
    [x,y];
    This is how the repeater scale looks like:
    var frameDelay = thisComp.layer(“CONTROLER”).effect(“Delay RepSize”)(“Slider”);
    var itemAbove = thisComp.layer(index-1).content(“Repeater 1”).transform.scale;
    var amountx = thisComp.layer(“CONTROLER”).effect(“Amount RepSize”)(“Slider”);
    var amounty = thisComp.layer(“CONTROLER”).effect(“Amount RepSize”)(“Slider”);
    [x,y];
    Any ideas on how I could add the increment on the Repeater’s Scale property to the Shape Layer’s Size?
    Thanks in advance!
    Pedro Amaral replied 10 years ago 1 Member · 0 Replies
  • 0 Replies
