Activity Forums Adobe After Effects Shape layers in 3D (in after effects)
  • Graham Quince
    February 9, 2024 at 11:40 am
    I think I’d use the include script Create Nulls from Path. And choose Points follow nulls. This will give you easy to adjust points (you can make the nulls 3D objects too).
    Ultimately it’s a 2D effect being faked in 3D, so you might be forced to switch to a 3D stroke. There is a plugin called 3D stroke, I think) or you could try with splines in C4D.
  • Christofer Kellgren
    February 9, 2024 at 2:08 pm
    Yes, i am putting it as a 3d object, and it works. And it works to shape it on the z-axis. But if you move one part up, it goes to the left and and etc. Nothing makes senses and it is hard to shape it as u want.
    Does the plug in work for ae?
