Activity Forums Adobe After Effects Expressions shape layer transform SKEW clamped to (-85,85)
  • shape layer transform SKEW clamped to (-85,85)
    Posted by Daniele Zacchi on August 20, 2019 at 4:51 pm
    hey all,
    have you ever encountered this limitation of after effects when you want skew a shape up to reach a flat 90 degrees distortion, but you can’t because the skew is clamped to 85 or -85?
    if yes… have you found any workaround or trick to solve it?
    thanks a lot for your help
    Daniele
    Alex Printz replied 7 years ago 2 Members · 1 Reply
  • Alex Printz
    August 29, 2019 at 9:27 pm
    start to non-proportionately scale your shape layer, or try animating your skew angle (or a combo).
    It’s because a true 90 degree skew would be infinite in one direction and zero in another.
    Alex Printz
    Mograph Designer
