Activity Forums Adobe After Effects Shape layer single line
  • Shape layer single line
    Posted by Hamid Rohi-bilverdy on May 8, 2016 at 7:33 pm
    Hi
    With the pen tool i create a vertical straight line(shape layer). I use the pan behind tool to move the anchor point to the bottom of the straight line.
    I then add a repeater. Set position value from 100 to 0 so the 3 default lines merges to one line. Then when rotating the extra lines is rotating from the middle instead of the bottom where i moved the anchor point to.??
    Kalleheikki Kannisto replied 10 years, 4 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    May 9, 2016 at 8:37 am
    You have to move the Transform anchor point rather than the shape anchor point.
