Activity Forums Adobe After Effects Expressions Shape layer hierarchy confused
  • Shape layer hierarchy confused
    Posted by Ilya Sire on April 27, 2017 at 8:37 am
    Hello, I have a question about shape layer hierarchy expression as here
    how to get opacity from Group 2> Rectangle 1> Opactity?
    Please help me
    Thank you
    thisProperty.propertyGroup(3)(1).transform.opacity
    Ilya Sire replied 9 years, 4 months ago 3 Members · 6 Replies
  • Xavier Gomez
    April 27, 2017 at 12:55 pm
    Maybe this:
    thisProperty.propertyGroup(6).content(“Group 2”).content(“Rectangle 1”).transform.opacity;
    or :
    thisLayer.content(“Group 2”).content(“Rectangle 1”).transform.opacity;
    Xavier
    thisProperty.propertyGroup(5)(“Group 2”).content(“Rectangle 1”).transform.opacity; would also work, but less clear imo.
  • Kyle Daily
    April 27, 2017 at 2:02 pm
    You can always pick whip the property to get its syntax.
    thisComp.layer("Shape study").content("Group 2").content("Rectangle 1").transform.opacity
  • Ilya Sire
    April 27, 2017 at 2:57 pm
    Yes it worked, but could you please explain me why propertyGroup(6)? How did you count it?
    I dont really understand about shape indexing.
  • Xavier Gomez
    April 27, 2017 at 4:05 pm
    In :
    you “get down 6 times” to go from the Layer to the Opacity.
    (Layer –> Contents —> “Group 2” —> Contents —-> Rectangle 1 —-> Transform —> Opacity
    Hence, the other way round, you need to climb up 6 times to go from the Opacity to the Layer.
    One thing to know is that every Shape Group inside a shape layer has a “Contents” and a “Transform”
    (similarly to the layer itself having a Contents and a Transform)
    The “Contents” step is hidden in the UI though, but it is still there somehow and must be accounted for.
    Xavier
  • Ilya Sire
    April 27, 2017 at 4:39 pm
    oh i see it. Thank you for your explanation.
    so i learned this way;
    1) counting from thisLayer down to property, be like:
    thisLayer.content(2).content(1).transform.opacity;
    2) counting from thisProperty climb up to other group, will be like:
    thisProperty.propertyGroup(6).content(2).content(1).transform.opacity;
    i guess level 6 = thisLayer is maximum
  • Ilya Sire
    April 28, 2017 at 4:12 am
    Thank you for this lesson. 🙂
