Activity › Forums › Apple Final Cut Pro Legacy › Shane Ross article on uprezzing using Compressor
Posted by Scott Davis on June 10, 2010 at 6:53 pmI had a link at one time to an article written by Shane Ross on using Compressor to uprezz SD files to HD. For the life of me I can’t find it. Would anyone have a link to this? I remember he was using footage of a ship as a demo.
Bill Finnegan replied 14 years, 11 months ago 5 Members · 8 Replies -
David Roth weiss
June 10, 2010 at 7:03 pmClick on Shane’s head above (lightly please, so as not to induce a headache) and you can easily find his tutorial/article on that subject.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Shane Ross
June 10, 2010 at 7:38 pmThat tutorial was my first, and it isn’t on the Cow. It can be found here:
https://pistolerapost2.com/shaneross/DV_to_DVCPRO_HD.mov
That shows how to go to DVCPRO HD, but you can make the final ProRes or whatever you need. Just not HDV..
Shane
Read my blog, Little Frog in High Def -
Scott Davis
June 10, 2010 at 8:02 pmThanks Shane, I am about to dive head first into doing a whole lot of this. I have a lot of archival material that are Qts that I need to get to 1080i. I am debating whether to use Compressor or lay out all my SD QTs in a sequence and put to Beta tape; then recapture using the Kona 3 to do the uprezz. If you had roughly 150 QT files to upconvert what would you do?
Shane Ross
June 10, 2010 at 10:03 pmAre the QTs in some regular format? Like Uncompressed 8 bit, or DV, or DV50? God, I think I would send them all to Compressor and spend a week crunching while I worked on other things.
Shane
Scott Davis
June 10, 2010 at 11:17 pmI only wish!!! Literally without exagerating the Qts are every format I can think of. MJPEG, DV, ProRess, a Blackmagic codec, etc. etc.
Tell me if this is idiotic or genius. I have cut in all the “Master” QTs into the offline cut. The cut is now locked and I am moving onto the online. I was thinking of taking the offline cut, duplicating the sequence, deleting everything except the QT archival material, laying that out to Beta, and then re-capturing from that Beta the clips and use the Kona to do the uprezz.
Shane Ross
June 10, 2010 at 11:24 pmTHAT is pretty genius. That is what I did before the Kona upconverted. Strung out all my SD footage, output to digibeta, upconverted via Terranex, recaptured.
Good call.
Shane
Neil Sadwelkar
June 11, 2010 at 12:44 pmYou could also remove all but the clips that needed uprezzing and then media manage the sequence using the batch recompress option setting a HD preset? That way you would also have handles, and preserve time code for future processing.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India -
Bill Finnegan
October 10, 2011 at 2:17 pmHi Shane,
I’ve been digging around looking for your tutorial on uprezzing using Compressor — the link I’ve found (https://pistolerapost2.com/shaneross/DVto_DVCPROHD.mov) seems to be dead. Any chance that is still out there somewhere? Or you have another post/tutorial that breaks this process down into steps?
I’ve got a basic iMac/Macbook Pro FCP 6 set-up, so hardware conversion isn’t an option, and I want to make sure I’ve got Compressor configured properly before I get it cranking. I’m finishing up a low budget 60 min doc, with 90+% of the footage shot in HDV and some archival footage that is SD NTSC and PAL.
Thanks for your help,
Bill
