Activity Forums Cinematography Shameless Promotion
  • Shameless Promotion
    Posted by Todd Mcmullen on January 3, 2007 at 4:23 pm
    Check out Friday Night Lights tonight on NBC-check your areas local time.
    I was the DP for this episode.
    we use 3 arri s16 cameras with no rehearsals or marks. actors play it where they feel, and usually not the same twice.
    It keeps you on your toes lighting wise. Lots of fun however, and lots of magical moments.
    Also look for hvx material. see if you can tell.
    Thanks for checking it out,
    Now back to your regularly scheduled program.
    Todd McMullen
    Flip Flop Films
    Austin
    Cinematography Forum Leader
    Todd Mcmullen replied 19 years, 7 months ago 2 Members · 2 Replies
  • Rmherd
    January 4, 2007 at 8:23 pm
    I watched the show. Those were some great performances. I couldn’t tell the difference between the s16 and P2, but I have a caveat: my cable company doesn’t offer HD. I live in the boondocks of South Lake Tahoe.
    I do however have a question: how do you organize your P2 cards, the footage, and the notes from the script supervisor? Literally, who do you give your P2 cards to when they’re full? What does he/she do with them? (Do you color correct then or later or at all?) Then where do those files go to integrate into the s16? Regarding s16, what is your transfer method? For example, do you convert film to DPX_2 or some other format?
    Basically, I was hoping for a literal breakdown of the process, including meta data and script supervisor notes, as well as creative/emotional influence on your decisions.
    Thanks a million!
    RH
  • Todd Mcmullen
    January 5, 2007 at 8:11 pm
    well, first off I was just hanging out in the boondocks of Homewood, on the west shore of tahoe. Man was it cold.
    regarding p2. I have used this quite a bit and everyone has an idea on how to handle it. It really depends on what editing system your editors are using.
    Most network and film people use avid. Theese editors take the mxf file and get it to the avis timeline then they output through a AJA or blackmagic card to a digibeta or whatever they are using.
    However, if you are using FCp then you can incorporate into your timeline and use it.
    here’s a p2 workflow:
    Shoot on p2 in whatever format 720 or 1080
    download full card to a hard drive for xfer to post facility.
    erase card for furthur recording
    film workflow:
    shoot film
    send to lab for processing
    film is xfered to hD or digibeta format
    input into editing system
    edit show
    lock edit and sound
    do color corection on final edit
    do on-line edit to master
    Not sure on metadata, sounds technical.
    Hope this helps
    cheers
    Todd McMullen
    Flip Flop Films
    Austin
