Activity › Forums › Adobe Premiere Pro › Shaky Footage: Warp Stablizer Won’t Work for This!
  • Shaky Footage: Warp Stablizer Won’t Work for This!
    Posted by Lisa Hurley on January 24, 2014 at 1:16 am
    Okay guys, there may be no solution to this problem, but I’m hoping there may be something to help me out a little. I’m all new to the DSLRs and haven’t completely mastered the technique yet, therefore, many of my clips are way shakier than I’d like for them to be.
    The shots that aren’t panning around I can fix with warp stabilizer, but where I have a panning shot that is shaky – well, that just doesn’t work…. so… I’m hoping someone here may have a trick up their sleeve they might share. I have tried working with the motion effects, and keyframes, which helped just a little – but other than this, IS there anything else I can do in post?
    Hopefully soon, I’ll have some decent stabilization equipment!
    Laurence Bartone replied 12 years, 7 months ago 5 Members · 5 Replies
  • Tero Ahlfors
    January 24, 2014 at 6:34 am
    You can fine tune After Effects’ Warp Stabiliser VFX effect but the Premiere version doesn’t have that. Also if you have super shaky stuff with motion blur it just might be impossible to stabilize.
  • David Lawrence
    January 24, 2014 at 6:50 am
    You might want to give Core Melt’s Lock & Load plug-in a try. I find it gives excellent results and is well worth the (low) price. Warp Stabilizer is great but I think Lock & Load is even better. Download the free trial and check it out:
    https://www.coremelt.com/products/lock-and-load-x.html
    _______________________
    David Lawrence
    art~media~design~research
    propaganda.com
    publicmattersgroup.com
    facebook.com/dlawrence
    twitter.com/dhl
    vimeo.com/dlawrence/albums
  • Lisa Hurley
    January 24, 2014 at 3:48 pm
    This looks awesome, and looking at their example of what it can fix, it appears that this would be just exactly what I need… however.. it is only for Macs, and alas, I’m on a pc. 🙁 I’m going to search for something along these lines that will work on a pc… Windows 7 – and at the same time, check out the after effects warp stabilizer. Thanks for the advice!!
    Lisa Hurley
  • Ann Bens
    January 24, 2014 at 6:47 pm
    The Warp Stabilizer can do wonders, it cannot perform a miracle.
    In other words not all clips are suited for stabilization.
    Panning and shaking, I think that is a bit to much…
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Laurence Bartone
    February 8, 2014 at 7:10 pm
    I’ve found Mercalli (ProDad) to save my butt on many occasions. I THINK it’s way more powerful than warp. Also, if you change the speed of the clip, then warp won’t work but Mercalli will. There’s a free way to try it out – with a logo on your sample.
    bartone.com
