Activity Forums Avid Media Composer Shaky Cam
  • Oakmozart
    June 6, 2005 at 12:55 pm
    Genarts Sapphire has one. I believe it’s called something like S_Jitter. In its default setting, if I recall correctly, it makes the frame shake so much you can actually see the “edges” of the frame. This is keyframeable to change that. It’s a cool effect and I’ve used it alot. I’m sure Grinner will attest to it as well, since he’s a Sapphire junkie! If you don’t have the loot for Sapphire, I don’t know of any plugins that will allow you to create this effect, though I’m sure you can do it in AE with an expression or two.
  • William Busby
    June 6, 2005 at 7:39 pm
    fwiw… BCC3 can also do this as well.
    Bill
