Activity › Forums › Adobe After Effects › Shaking in transition and still
  • Shaking in transition and still
    Posted by Girshon Rutstein on June 16, 2010 at 12:25 am
    I created video with dissolve transition and 3 sec still at the end in FCP6. When I render these 10 sec clips in after effects HD 1920X1280 I see vibration or shaking in the transition are and in the still.
    I tried to deinterlace the ending freeze frame it did not help.
    What can cause this effect?
    Girshon R
    Girshon Rutstein replied 16 years, 3 months ago 2 Members · 4 Replies
  • Kevin Knutson
    June 16, 2010 at 8:23 pm
    How are you rendering in AE? Are you rendering lossless? Which codec, etc?
    How about composition settings? Do they match the footage you brought in from FCP?
  • Girshon Rutstein
    June 16, 2010 at 8:56 pm
    FCP export self contain 1080i60, AE Pro res 422. 1920×1280 I did not know that it should match. I never had to, in the past. I would like to correct myself, its jitter horizontally, not shaking
    Girshon R
  • Kevin Knutson
    June 16, 2010 at 9:13 pm
    And just to clarify, is the problem showing after a full render from AE, in a video file, or is this happening during a RAM preview inside of AE?
  • Girshon Rutstein
    June 16, 2010 at 9:31 pm
    After the final render
    Girshon R
