Activity Forums Adobe After Effects Shake the screen Tutorial
  • Shake the screen Tutorial
    Posted by Xtothed on May 19, 2006 at 2:21 pm
    Hi Guys,
    Been searching everywhere, trying to find tutorial where whole screen shakes – it was Andrew Kramer’s I think – where a guy hits a baseball….does anyone have a link?
    Xavier
    Mike Clasby replied 20 years, 4 months ago 5 Members · 4 Replies
  • Aharon Rabinowitz
    May 19, 2006 at 2:33 pm
    I haven’t seen that tutorial, but you can use the Wiggler (Window > The WIggler) to create the shake.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Markofcain
    May 19, 2006 at 3:19 pm
    https://www.videocopilot.net/tutorials.html
    Tutorial # 5 “Camera Shake”
  • Accountclosedduetonorealnameused
    May 19, 2006 at 4:32 pm
    make a new Null, attach all layers in your shot to the Null.
    apply this expression to the Position parameter:
    n = position.numKeys;
    if (n > 0){
    t = time – position.key(n).time;
    if (t > 0){
    freq =8;
    amplitude = 10;
    decay = 6.0;
    s = amplitude*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    e = amplitude*Math.sin(freq*t*1*Math.PI)/Math.exp(decay*t)
    value + [s,e]
    }else{
    value
    }else{
    value
    then add a keyframe for position at the time you want your “impact”
  • Mike Clasby
    May 19, 2006 at 5:33 pm
    I really like Scott Frizzle’s free preset “Quaker” for shaking things up:
    https://www.scottfrizzle.com/free_quake.html
    Comes with a pdf and movie. Easily controlled with sliders for Quake Magnitude, Quake Frquency and Motion Tile (fills in the gaps so you don’t have to size-up the fottage before you shake it and create gaps along the edges).
    As a preset, just use Animation > Apply Animation Preset and navigate to where the quaker.ffx file is (or drop it in your folder >Support Files > Presets.
    Scott also has some nice free Particular setups available also.
