Activity Forums Adobe After Effects Shake, jitter, etc. I’m a noob.
  • Shake, jitter, etc. I’m a noob.
    Posted by Wtcrei7 on August 23, 2007 at 10:54 pm
    Hello,
    Please forgive my idiocy.
    I’m having some images move across the screen from R to L in AE CS3. The images take up about 3/4 of the screen and are shaking or jittering pretty badly.
    I tried applying an adjustment layer and the various settings of the effect “reduce interlace flicker” with no luck. I also tried deinterlacing in photoshop and then re-imported into AE with no luck. I also added “directional blur” in AE without any success either. I altered various values of shutter angle, shutter phase, and samples per frame and nothing works.
    The images move across the screen fairly quickly. Some layers are parented to others. Is it impossible to eliminate the shaking? I want the images to be clear, without blur. I imported the footage into Final Cut and then viewed it on a TV screen but it didn’t make any difference. Only when I slow the images down significantly does the shaking stop. But I need pretty good velocity.
    Any help is appreciated! Thanks in advance.
    Kuaishou replied 19 years ago 2 Members · 1 Reply
  • Kuaishou
    August 24, 2007 at 6:39 am
    hi…could it b that u r rendering in frames?…try rendering in fields…maybe thats the solution…cheers…merv
