Activity Forums AJA Video Systems Shake and Io
  • Shake and Io
    Posted by Leandro Krukowski on April 23, 2005 at 4:17 pm
    I was at the AJA booth at NAB and talked to an AJA rep that said it was possible to get video out of Shake through the Io. But I can’t remember how he said I could do it… can anyone help?
    Tony! Hulette replied 21 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Adam Schmidt
    April 24, 2005 at 4:56 am
    I have shake 3.0 and I can NOT get the io to act as a BC monitor. In theory, under globals, under broadcast quality or render quality (can’t remember witch), you will find a slider for broadcast monitor. Move it to #2 if you have one monitor or #3 if you have two computer monitors. Click the TV looking button on the main window. If you get video, your set, if not call aja.
    Adam
  • Ilpoldo
    April 24, 2005 at 9:13 am
    Is not working for me on shake 3.5(trough a io LA), maybe I’m missing something…
    Leandro Pedroni
  • Stuart Ferreyra
    April 24, 2005 at 10:18 pm
    I read that Shake 4 will have compatible output for the Kona2 and other cards.
    I hope that since Kona2 and Io are made by AJA, and that Apple writes the code
    for them, it will output as well.
    Let’s talk to the AJA guys.
    Stuart C Ferreyra
    Timecode Multimedia
    President
    https://www.timecodemedia.com
    12340 Santa Monica Blvd.
    Suite 230
    Santa Monica, CA 90025
    310/826-9199
  • Adam Schmidt
    April 24, 2005 at 11:09 pm
    My kona 2 works with shake 3.0
    Adam
  • Ilpoldo
    April 25, 2005 at 7:37 am
    We are not talking about Kona 2 here, wich, I guess, works as advertised.
    The first message of this thread was about Io. I knew that Io family wasn’t able to do shake broadcast monitoring. Has something changed?
    Otherwise I can’t grasp the sense of this thread.
    Leandro Pedroni
    Freelance editor
    Italy
  • Adam Schmidt
    April 25, 2005 at 6:03 pm
    ilpoldo,
    Stuart, in his comment before mine, was wondering if the kona 2 ran with shake 4. My kona 2 runs with shake 3 just fine, and I thought he would like to know.
    no confusion here,
    Adam
  • Tony! Hulette
    April 25, 2005 at 10:55 pm
    [Stuart] “I read that Shake 4 will have compatible output for the Kona2 and other cards.
    for them, it will output as well. “
    Apple writes the drivers for the Io, but not for the kona cards – AJA does that themselves. Its my understanding that Shake 4 will be supported with the new Io drivers due out sometime in May. Its possible with Tiger’s core audio and video that we’ll see a lot more applications supported as well in the near future.
    Tony!
