Activity › Forums › Boris FX Sapphire › Shake
Shake
Posted by Jack James on November 26, 2007 at 11:54 pmHi
I’m sure this is a simple one but none the less any help would be greatly appreciated!!! Does anyone know how I remove the thin black frame/line which wiggles around with my shaking image?
Thanks!Jack James replied 18 years, 10 months ago 2 Members · 4 Replies -
Gary Oberbrunner
November 27, 2007 at 3:53 pmSure, Carl: just turn Z Dist to 0.99 or so (just a little less than 1) to zoom in a little bit. If you’re on Avid, you can use the crop/transform controls to crop out the black edges instead.
— Gary
Jack James
November 27, 2007 at 4:40 pmHi gary
Thanks for your help thats great, the only problem I still have is on the shots where its really really cranked up and the frame wobbles in quite significantly..(a good 1/4 of the screen). Any suggestions?
Thanks Again
P.S
I should have said in the first post but yeah I’m on Avid -
Gary Oberbrunner
November 27, 2007 at 5:39 pmNo problem. On Avid, just open the Crop/Transform control group, and adjust the Crop Left/Top/Right/Bottom controls to remove the black edges. Of course 1/4 of the screen is a lot of shaking!
— Gary
