Activity Forums Maxon Cinema 4D shadows on a transparent background
  • shadows on a transparent background
    Posted by Olly Bea on February 1, 2011 at 1:11 pm
    Hey all
    I have been reading a few posts on this but none of the threads seem to quite achieve what I am after so I wonder if anyone can help.
    I have an object, for arguments sake lets call it a cube, now I need a .png rendering out which will keep the background transparent (as I want to add my own background in post), I have also added a plane on which the cube sits, and a light which is casting the cube’s shadow onto the plane. Now here is the tricky bit. I need the cube’s shadow (and all it’s feather edge and alpha) but without the plane.
    So basically it just renders the cube and the shadow against a transparent bg .png
    Is this possible?
    Many thanks in advance.
    Olly
    Dean Mellis replied 15 years, 7 months ago 2 Members · 1 Reply
  • Dean Mellis
    February 24, 2011 at 6:53 pm
    I’m also looking for a solution to this answer. I’ve tried several tutorials. Some on this site that use composite tags, but they do NOT work. I don’t mind fussing with alpha channels in Photoshop, but none isolate the shadow.
