Activity Forums Adobe After Effects Shadows going through solid layers
  • Shadows going through solid layers
    Posted by April Henderson on December 23, 2009 at 9:28 pm
    Hi. I was just wondering if it was normal for a shadow to be going through a solid layer.
    I have not instructed any layers to do so.
    The object casting the shadow, however, is a precomposition, mind you with the “collapse transformation” icon selected.
    Anyways, the shadow is going right through solid layer it’s sitting on and passing down to another layer (where I don’t want it).
    Any advice? I don’t want to turn off shadows for the layers below because they have their own lights and shadows.
    Steve Blacker replied 16 years, 9 months ago 2 Members · 2 Replies
  • April Henderson
    December 23, 2009 at 9:44 pm
    I substituted the precompositioned layer for just a normal layer and the shadow is still going through. So that doesn’t seem to be the issue.
  • Steve Blacker
    December 24, 2009 at 2:51 am
    Put an empty adjustment layer between the layers. That way you re-arrange the rendering order, as it were, and you won’t see a shadow pass through to the layer below.
    Then you just put your other light/layer/shadow casting object below the adjustment layer, etc.
    It’s only work if you’d rather be doing something else…
