Activity Forums Zaxwerks Shadows and Transparency Maps
  • Shadows and Transparency Maps
    Posted by Sean Maloney on October 24, 2007 at 9:58 pm
    Hello-
    In Invigorator Pro 4.3.1, I’ve created a sphere that resides inside (right in the middle) of a slightly larger sphere. I used a transparency map to cut text out of the surface of the outside sphere so you can see through to the inside sphere. I can’t get the outside sphere to cast any shadows onto the inside sphere though – is that a limitation of transparency maps? I have Shadow Casting enabled on the Zaxwerks lights and have also tried using Comp Lights – neither seem to work.
    Thanks for any help you can provide.
    Sean
    Sean Maloney replied 18 years, 11 months ago 2 Members · 2 Replies
  • Serge Hamad
    October 24, 2007 at 11:18 pm
    [spmaloney] “is that a limitation of transparency maps”
    Yes! But there is as always a workaround;-)
    -Duplicate your transparency map in your ae project window after you are done animating it. (I assume that you are using the layer mapping technique)
    -Now open this duplicated comp and reduce the transparency of your text layer.
    -Blur your text to taste
    -Apply the duplicate to your inner sphere as a texture map.
    Done!
    Here is an example aep for you: https://www.nyc-visual.com/Shadow.zip
    Salut.
    Serge
    “InvigoMany” is back in stock! https://www.nyc-visual.com
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • Sean Maloney
    October 25, 2007 at 1:38 am
    Brilliant! Thank you so much!!
