Activity › Forums › Maxon Cinema 4D › Shadows and compositing tag
Posted by Per Sverre wold-hansen on June 15, 2014 at 10:21 pmI just want to render out a TGA or PNG where an object-shadow on the ground (a simple Plane) is kept in the image along with an Alpha channel. Ground not seen. I need to use this image on a web-page with the Alpha. I’ve done this before, but now I can’t…
I have used a Compositing Tag on the ground and turned seen by camera OFF. Most others are ON. I get no shadow (alpha) in the TGA.
Seems like the shadow is disappearing along with the Plane…
PerS
Chris Holland replied 11 years, 1 month ago 5 Members · 9 Replies -
Adam Trachtenberg
June 16, 2014 at 4:30 amYou mean you want to isolate the plane with an alpha, or the shadow?
June 16, 2014 at 1:10 pmHi Adam – Sorry for being unclear.
The reason for the plane being there is solely for the purpose to get a shadow – cast by the object. I thought I could “remove it” (and not the shadow) by the Composition Tag.
The “end product” should be a PNG w/alpha holding the masked object and its masked shadow – The PNG is to be put on web-page. The shadow helps mimmic an impression of depth on that page – Keeping the page’s gradient backdrop.
PerS
Adam Trachtenberg
June 16, 2014 at 4:07 pmOkay, gotcha. The way I would generally go about this would be to render out a shadow pass and then multiply that over the background. But since you want the alpha the easiest way to do it is to use the free shadow catcher plugin: https://www.thepixellab.net/cinema-4d-free-shadow-catcher-plugin
June 16, 2014 at 10:09 pmOK – I think I understand. However, “a shadow pass” is slightly beyond me. Your link, though, is very interesting. Joren’s “thepixellab.net” is one of my favorite C4D sites. Interesting place. I justed visited, downloaded, watched the tut – and tested the plugin.
Amazing – It works (in R14 Studio)! So this saved my butt. Thank you very much for your time, Adam!
PerS
Simon Huang
June 21, 2014 at 4:53 amOh, I just solved this problem just yesterday.
Download “shadow-catcher” and apply the mat with shadow catcher to the floor. Render as “PNG” file and alpha channel.Cheers.
June 22, 2014 at 12:46 pmThanks for your tip – which also got from Adam. Works fine!
PerS
Chris Holland
August 14, 2015 at 2:50 pmWill this work with Cineware in Aftereffects ?
I am having a really hard time getting this to work. It just won’t transfer the shadow over
Chris Holland
Editor/Animator -
Cassius Marques
August 14, 2015 at 7:07 pmif you want to get alpha shadow with cineware just set a white plane on c4d and make sure it gets the shadows…set an object buffer for that plane.
Within AE duplicate your cineware layer…turn on its pass mode to that object buffer.
Use that as a matte for yout main cineware layer that you can later either remove the white or simple change it to multiply.
Chris Holland
August 21, 2015 at 5:57 pmThanks.
I finally had a chance to mess with this today and got it to work. Appreciate the help.
One thing to add is to get a full on white plane I had to add a background and and composite it to the floor or the floor was picking up the light and having a gradient and it would’t matte 100%.
Is there a way around that besides adding the BG and compositing it that you know of ?
Thanks.
Chris Holland
Editor/Animator
