Activity Forums Zaxwerks Shadow pattern
  • Shadow pattern
    Posted by Juaquin Sanchez on August 19, 2014 at 2:35 pm
    When I render a single frame I am getting a banding/pattern where there are shadows. Is there a way to fix this?
    Edward Wu replied 12 years ago 2 Members · 1 Reply
  • Edward Wu
    August 22, 2014 at 9:09 pm
    Hi Juaquin,
    From your descriptions, it sounds like you may be using a low quality Shadow Map. Try going into the Lighting Globals panel and increasing the size of the Shadow Map. After doing this, the shadows should look a lot better.
    Hope this helps. If you are still having problems, please send the project file to me at ed@zaxwerks.com and I’ll take a look at what you are running into.
    Best,
    Edward
