Activity Forums Maxon Cinema 4D Shadow pass
  • Brian Jones
    July 31, 2012 at 3:04 pm
    the first guess without the file is that the rim of white is a always there like it’s picking up light from another light or by GI from the white floor. Do you have another light or GI turned on?
  • Adam Trachtenberg
    July 31, 2012 at 3:43 pm
    The problem is caused by anti-aliasing. The only way to fix it, AFAIK, is to select the multi-pass page in render settings, set “separate lights” to all, and then check the “shadow correction” box.
  • Tim Monaghan
    July 31, 2012 at 4:46 pm
    Perfect, Thanks Adam!
