Activity › Forums › Zaxwerks › shadow on 3d object
  • shadow on 3d object
    Posted by Rdub on August 28, 2010 at 6:52 pm
    I have a spinning basketball with text in front. I would like to have the text cast a shadow of itself on the basketball. I’ve tried implementing what I have read but no luck. Can I cast the text as a shadow on the ball?
    Edward Wu replied 16 years, 1 month ago 2 Members · 1 Reply
  • Edward Wu
    August 31, 2010 at 12:09 am
    Hi Bill,
    Sure, to have the text cast a shadow onto the text, set up the light so that it is in front of the text and the basketball, and be sure the light has “Casts Shadows” applied. Then, when you do a test render (holding down the Ctrl/Cmd) key, you should be able to see the shadows.
    Best,
    Edward
