Activity Forums Adobe After Effects Shadow Casting
  • Shadow Casting
    Posted by Clayton Light on April 19, 2009 at 6:00 am
    I’d like to place a fractal noise animation (I have it as a layer and a rendered .mov) in front of a light and cast a moving shadow on my subject. As I’m trying it, I just keep getting the whole layer as a block and not the animation. I have the layer set to cast shadows only. It seemed to work at first but when I positioned it, I just got a frame sized block.
    Any advice?
    Clayton Light replied 17 years, 5 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    April 19, 2009 at 6:08 am
    Sounds like it doesn’t have an Alpha Channel that cuts out the RGB channels. Try the Set Channel plugin to create an ALpha from one of the RGB Channels, whichever gives the best result.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Clayton Light
    April 19, 2009 at 6:11 am
    Good idea, I’ll try that right now.
  • Clayton Light
    April 19, 2009 at 6:15 am
    That did the trick! Thanks.
