Activity Forums Maxon Cinema 4D Shader Effector Mograph question
  • Shader Effector Mograph question
    Posted by Michael Taylor on July 10, 2009 at 5:46 pm
    Hi I want to take a still image and map it over a group of clones arranged in the grid array, so each clone makes up part of the image, a sort of mosaic. Is there a good way to achieve this? DO I need the shader effector? It’s a confusing little plugin. Any help would be appreciated, thanks.
    Ole Sturm replied 16 years, 1 month ago 3 Members · 4 Replies
  • Brian Jones
    July 11, 2009 at 5:54 am
    it sounds like a texture on the Cloner Object set to Flat mapping (you’ll have to resize it up to cover all the clones)
  • Ole Sturm
    August 24, 2010 at 1:53 am
    Hi Michael,
    I’m trying to figure out the same thing – how did you end up working it?
    Ole
  • Michael Taylor
    August 24, 2010 at 11:46 am
    Yea change the texture to flat mapping and adjust the image on your model using the scale and offset.
  • Ole Sturm
    August 24, 2010 at 11:40 pm
    Hi Michael,
    I’ve not been able to get this to work. I’ve assigned a texture directly to the cloner object but I cannot find an option to set flat mapping anywhere.
