Activity Forums VEGAS Pro SFK files to C:?
  • SFK files to C:?
    Posted by Ernest Rosado on October 24, 2014 at 10:51 am
    I recently started at a new editing gig where I fought tooth-and-nail to get them to buy me a copy of Vegas (they’re a WaveLab house). Finally won that battle, but I got reprimanded yesterday for all the SFK files that now litter our shared network drive. Apparently the files are getting in the way of the other editors. We’re required to do all our edits from the network drive as the files we edit are constantly updated, so copying the media to my local hard drive is not an option (plus all that’s in my machine is a tiny SSD which is nearly full anway).
    How can I force the SFK files to be generated on my local hard drive rather than alongside the media? I’ve scoured the preferences and have not found anything.
    Thanks in advance!
    Ernest Rosado replied 11 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Graham Bernard
    October 24, 2014 at 11:15 am
    [Ernest Rosado] “How can I force the SFK files to be generated on my local hard drive rather than alongside the media?”
    You can’t.
    Grazie
  • Ernest Rosado
    October 24, 2014 at 11:28 am
    Is there any solution at all? :\
  • Graham Bernard
    October 24, 2014 at 12:25 pm
    Don’t use Vegas? – Seriously, other NLEs DO have the option to have the Project files filling separated Project Folders, but NOT Vegas.
    Grazie
  • Mark Barton
    October 24, 2014 at 3:07 pm
    The VASST MediaTool app will make it easy to remove these files afterwards, but while you are using Vegas, they would still be there.
  • Ernest Rosado
    October 25, 2014 at 7:35 pm
    I’ve discovered that if I have write permissions removed from the folder that contains the media then SFK files are not created there and Vegas still operates normally, it just has to rebuild visualizations every time you load a project.
    This proves that Vegas CAN operate without SFK files, Sony just doesn’t give you the option. Booooo. 🙁
  • Ernest Rosado
    October 25, 2014 at 7:36 pm
    The solution I’ve found is to have them take away my write permissions from the media folders. Seems to work fine.
  • Aleksey Tarasov
    October 26, 2014 at 10:39 am
    You call this a solution? 🙂
    Just don’t pay attention to these files.
    (finally, you can delete them all at once)
  • Ernest Rosado
    October 27, 2014 at 2:58 am
    Hi Aleksey,
    The problem is that the other team of 10+ editors see the .sfk on the drive and have complained that it clutters the folder. As I am using Vegas all day, deleting them at the end of the day doesn’t solve the problem. They shouldn’t be created on the media drive to begin with, and I wish Sony would give us that option as it’s not necessary for them to be alongside the media file for any technical reason whatsoever.
    Thanks to everyone for your responses.
