Activity Forums Apple Final Cut Pro Legacy Sewing Two Shots Together
  • Sewing Two Shots Together
    Posted by Caleb Wheeler on December 28, 2014 at 5:24 am
    I’m wanting to sew two separate shots together, both on the same plain of a lateral swivel. I want to fuse them in such a way that the motion and background are both consistent between the shots while also allowing the character subjects to inhabit the frame at the same time. I’ve manipulated opacity to give you an idea of what I’m wanting as the final product but I don’t think opacity is the answer. HELP.
    EXAMPLE VIDEO: https://reels.creativecow.net/film/22685
    Nick Meyers replied 11 years, 8 months ago 4 Members · 4 Replies
  • Roger Poole
    December 28, 2014 at 2:32 pm
    I’m reading your post on an Android tablet which doesn’t support flash so I can’t view your example but I suspect composite mode might be what you are looking for. Undo your opacity change first.
  • Massimo Alberto croce
    December 28, 2014 at 6:32 pm
    Rotoscoping in motion.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Nick Meyers
    December 28, 2014 at 8:58 pm
    most basic way is to keyframe the crop
    if that doesn’t give you enough control, the next level up is to keyframe a garbage matte, 4 point, or 8 point
    both of these approaches have issues due to FCP not having much control over the feathering: it’s universal, same feather on al sides including the edges of teh frame where no stitching is required.
    one way is to layer a feathered version on top of a non-feathered version with a slightly offset animation,
    if you’re very lucky a wipe transition might work, but you;d have the least amount of control over that.
    or use motion
    nick
  • Nick Meyers
    December 28, 2014 at 9:03 pm
    also, the rotational speeds of the two shots are slightly off,
    adjusting speeds would be the hardest and give you unwanted artefacts,
    simply keyframing the left / right position of one shot would be the simplest.
    it;s not impossible in FCP doing it manually, (quite simple, really)
    but using one of the tracking tools in motion should be more accurate.
    nick
